This evening I continued work on the baffling. - I primed the pieces that will be riveted together. - Cut the hole for the sparkplug sires - Drilled the center hole in the back pieces - Installed all pieces to mark the holes for the blast tubes - Started work on the curved side pieces at the inlet
