Mounting the engine mount to the fuselage was actually pretty easy. We put small bolts through the existing holes and then drilled the 4 corner holes to size. The two mounting brackets next to the gear were a bit away from the firewall, so before drilling them out we tightened everything down. Then, when we mounted the mount for good, we used large washers between the mount and the firewall.
