This evening, I completed cutting out the insulation for the firewall. Again, I made patterns for each of the pieces. I ended up using almost the entire piece of insulation.
Tip - I ended up changing the razor blades I was using often. Cutting with a new razor blade is much easier.
I put all the pieces aside and will install them when everything else is installed.
