- Drilled holes in control column and control stick ends - Trimmed 3/4 inch pushrod to correct length - Filed, ground, and polished bushings to correct length. - Assembled control stick pushrod (will call Van's with question about control rod length)
Took elevator pushrod assembly home to prime the inside before assembly.
