Finished drilling the gear mounts. Took them off and deburred. Then, bolted them back on.
Drilling the two front attachment holes turned out being easier than I thought it would be. I connected the left side gear mount outside the fuselage on the right side. (Using the five bolt holes I drilled yesterday to line everything up.) You might want to check out the pictures... but it worked GREAT!
Dad came by in the afternoon and helped me put in one of the bolts on the landing gear mount. Two of the were buggers to put in.
Next, we mounted the steps.
Using opposite gear mount as guide for front holes
