I ran the brake lines from the pedals to the fuselage fittings. Both fittings had to be tightened so I ended up removing them and blowing them out to make sure they were clear. (I also ran compressed air through the lines before installing them.
I temporarily ran a line from the fitting to the brake fitting on the wheel.
