This morning I worked on checking out the installation of the back window. I clecoed the back skin on then worked at installing the window. The backup metal I had drilled and fitted to go on the back side of the window doesn't fit. It's close, but the holes are enough off centered to make it look crappy. I'll need to re-do them. I think it will be best to construct them while the back canopy window is installed.
