I started late this evening. I had to go to a nearby city to help my wife drop off her Prius. (The way she drives, she would never know if the gas pedal was sticking down. It's always pedal to the metal:-) I received a couple of cool gadgets in the mail.
- Fuel warning indicator - these little guys sense when the fuel gets to a certain level and light up. Warning you to switch tanks of find an airfield.
- Oil level sensor - this device screws into one of the engine oil drain plugs and lets you know when the level of the oil is low.
I cleaned up the shop and cut the clear cover for the lights. I worked over it on the sander to start getting it closer to the shape needed.
