New aluminum angle iron came in yesterday. (Ordered to replace the goof from last week)
Used a hacksaw to cut the aluminum angles to size. (Rough size) The table belt sander ground the angles to correct size. Polished with CAREFULLY drilled alignment holes. Drilled other 16 holes. CAREFULLY DIDN'T drill the 3/16 inch holes!!
