ALAN'S WEB SITE
RV-9A
DWG 3
Attach Hinge Bracket
On my quest to finish up some jobs I skipped over, this evening I went back to work on the horizontal stabilizer.
First job - Attach the hinge bracket
- Drilled holes to size
- Bolted bracket to spar
- Torqued bolts
(One of the reasons I hadn't done this earlier was not having a torque wrench that was calibrated in inch pounds)
Bolts being torqued
Inserting rod end bearings
Critters for getting hinges in correct spot!!
RV-9A Home
1811
207
Cowling
311
178
342
Inspection
Panel
49
121
166
