Brief Description: Connect Rudder to Horizontal Stabilizer
This evening I built a bearing bolt tool out of PVC pipe. I was wondering how I was going to get the bearing bolts screwed in. (There isn't much room) Looking at other builders logs, I came across something similar to the tool I came up with. Then, I needed to try it out. So, I screwed in the bearing bolts into the rudder and connected it to the horizontal stabilizer. It ended up taking more adjustment than I realized. But, in the end the rudder swings freely.
