ALAN'S WEB SITE
Date:  10-27-2008
Number of Hours:  2.25
Manual Reference:  8-1 to 8-4
Brief Description:  Fuselage Inspection
I continued through the instructions carefully checking the work on each step. There were a few things that weren't completed, so I worked on them.
Brake Bracket - Drilled, deburred, and dimpled the firewall where the brake bracket connects. (Used the pop rivet gun with dimpling dies) I also countersunk the holes in the bracket and smoothed the edges
Firewall Recess - Drilled, deburred, and dimpled the firewall recess unit. Then, squeezed the rivets on the unit itself. (The recess unit is riveted to the firewall much later.)
Pop rivet dimples
Pop rivet dimples
Firewall recess
Firewall recess
Brake bracket
Brake bracket
