After fitting the top cowling on, it was apparent that I needed to trim the front baffling where the baffling meets the inlet cowling scoops. (The scoops were glassed onto the top cowling.)
I measured where to cut with the cowling on. Then, I used tin snips to sneak up on the line. After I was close, I used a file to complete the cut.
