One of my EGT sensors has been WAY out of wack since it was installed. I talked with Dynon and they said about the only thing to do is to trace down the wiring for the bad one. This evening, I dove into the task.
After removing all the zip ties on the left side, it didn't take long to find the problem. One of the connections was loose. (It was actually attached at the factory.) I repaired it and put everything back together again.
I used adel clamps instead of zip ties. When Cory wired the sensors up, he used zip ties on one side and adel clamps on the other. I like the looks of the adel clamps.
