My goodness, this ended up being a much larger project than I thought it was going to be.
I mounted the antenna onto the rear channel above the baggage compartment and routed the wiring down the brace and under the seats. The real chore came when I took it through the forward channel and up the firewall. (I had wrapped the existing wiring in tubing so I had to unwrap it then wrap it back up.)
