I had drilled the hole for the ELT antenna a while back but for the antenna to fit correctly, I needed to file down a bit of the base. I drilled the holes for the antenna wire and installed grommets. (I also switched out the nut on the antenna base. I used one from another antenna. The nut was so big it didn't want to turn easily.)
