I ran the electrical conduit down the right side of the fuselage this evening. Again, I ran the braided conduit and ran the electrical through it. This run includes the wires for the Dynon unit in the back of the plane and the autopilot. I also had just enough room for the static air line. It ended up being 17 runs.
I had to drill one of the holes a bit larger to fit the static air line through it.
This braided conduit is REALLY tough. I had to use tin snips to cut it. I melted then ends to keep them from unbraiding.
