ALAN'S WEB SITE
Date:  9-29-2010
Number of Hours:  3.00
Brief Description:  Wiring run down right side of fuselage
I ran the pilot and copilot headset electrical to the luggage compartment. I also ran a line for the lbaggage compartment light and a light that aims forward into the cockpit. I also ran the antenna coax for com 1.
I used a braided conduit that actually worked great. I ran all the lines 4 different times. (And learned a bit more after each run. I had to run the antenna coax first because of the size of the fitting on the end.
