KEVIN'S WEB SITE
Date:  7-18-2010
Number of Hours:  1.50
Brief Description:  Attached ruddervator to left stabilator
Drilled piano hinge #40 and #30. Clecoed in place. Struggled at first in placing rod back in hinge. Then got the idea to take hing off stabilator and place rod in first. I then clecoed rudderbator and hinge to stabilator. Had to redrill several holes because I didn't get the hinge set straight the entire distance.
All that is left for left stabilator is to finish drilling all #40's to #30's and debur. Can't rivet at this point until they are attached to the fuselage.
