KEVIN'S WEB SITE
Date:  6-23-2010
Manual Reference:  WIX-T10
Brief Description:  Hockey stick (spar cap) prep/drill ribs
Drilled pilot holes in hockey stick spar caps. Used drill press. Deburred. Positioned, drilled and clecoed hockey stick to forward spar. Began drilling spar and ribs to begin assembly of the stabilator.
Made a mistake! Used the left aft spar when I should have used the right. Misread the plans. Hopefully won't be an issue once I switch them. Also attached the rib clips utilizing 5/16 bolts.
