More wing skins to remove for the upgrade. Drill rivet... tap it out... drill rivet... tap it out... repeat as needed untill desired effect is achived! What a task! Its easy work but wow is there a lot of rivets. My back and wrists are killing me. Worked till 11:00. wanted to work more but I got to be able to work in the morning. Had Scott take a few picts of me working. Will try to get more as I go. I need a camera with a timer so I can get some while Im alone.
tapping out drilled rivets
pulling back the leading edge
leading edge exposed and starting on the top wing skin section.
