Trimmed Nose Rib 1&2 to fit new spar mods. Drill out rivets and remove flap hinge from wing. Removed root duobler from rear wing chanel.
Drilled and removed a bunch more rivets again. I also measured marked and drilled the aileron rod hole doubler. will take it to work and see if I have a hole cutter that will make my opening without mucking it up! Not much to write about but feels like I made some good progress today! Will upload the photos later.
