Marks Web Site
Date:  4-13-2011
Number of Hours:  3.00
Brief Description:  Remove wing skins for upgrade
More wing skins to remove for the upgrade. Drill rivet... tap it out... drill rivet... tap it out... repeat as needed untill desired effect is achived! What a task! Its easy work but wow is there a lot of rivets. My back and wrists are killing me. Worked till 11:00. wanted to work more but I got to be able to work in the morning. Had Scott take a few picts of me working. Will try to get more as I go. I need a camera with a timer so I can get some while Im alone.
tapping out drilled rivets
pulling back the leading edge
leading edge exposed and starting on the  top wing  skin section.
