Chuck S. Sportsman 2 +2 Site
Date:  10-6-2006
Number of Hours:  5.00
Brief Description:  Electric elevator trim servo installation
-Steps 15 to 24 -clamped trim tab in neutral postion with masking tape-ensured servo pushrod rod end is in safety-servo mounting holes drilled into top elevator skin-nutplates installed under elevator skin with flush rivets-aluminum servo cover plate manufactured and flanges adjusted to fit flush-plate attached to top of servo temporarily with tape-servo removed and holes backdrilled through cover plate-servo and cover plate re-installed-operate servo with 9.6 battery-pushrod slot checked for clearance through full range of tab travel-slot trimmed to allow rod clearance-long wiring harness soldered to servo leads and attached to control horn, grommet installed in elevator skin-5 pin electrical connector installed at servo using MODE 37-206-1 connector kit (connectors and pins supplied with kit inadequate-wiring checked for security
