Brief Description: Step 90 Fabricate the forward spring block
-make fwd spring block from alum block-grind to shape on belt sander, test fit -drill 3/8” hole in center perpendicular to flat side (bottom)-drill 12 bonding holes as shown on drawing-deburr, clean, alodine and prime with zinc chromate
