Brief Description: Elevator/Aileron Control (Step 8)
-Located all the parts necessary for this assembly.-Squeezed bushings into control yoke and pivot brackets.-Drilled #10 hole in the pivot bracket so a clevis pin could be installed.-Installed clevis forks unto the ends of the control-stick tie-rod and connected them via clevis pins to the pivot bracket.
