Chuck S. Sportsman 2 +2 Site
Date:  9-17-2006
Brief Description:  Vertical fin Rivet Holes
-Marked out spacing for the rivet holes. -Drilled the holes thru the flange. (Extra care had to be taken while doing this task because the length flange was so small if the hole was not centered there would not be enough edge distance or no room for squeezing the rivet.
