Brief Description: Fabricate, Position, and Drill Forward Attach Angl
-read thru details contained in Step 76, Sec8-locate 1x1x.063 angle stock then fabricate the forward attach angles; includes design/layout, cut, and drill for bolt holes to dimensions specified in the manual-established a left and right layout on b/h C for positioning the two brackets as detailed in the manual(Fig 95)-performed aligning, clamping, and sequential drilling as necessary to match drill the bolt holes from the brackets to the bulkhead
