-Threaded jam nut unto pushrod.-Began threading the rod ends unto the push rod but the stop moving before the inspection hole was reached. Inspected threads and it seemed that the threads on the push rod was causing the problem. Used tap and dye set to form new threads on the rods for the left and right ailerons.
