-Located the strut fitting.-Used loctite and pressed bushings on strut attach fitting.-Applied epoxy primer on the inner surface of the strut and outer surface of the fitting.-Installed fitting into the strut. The bolts that were given used nylon nuts. For this assemble, it is preferred to used castle nut and cotter pin for inspection purposes. The correct type of bolt was not in stock and an order was placed for them.-Removed aileron and flaps from the racks and placed them on the table in bay 4.
