Brief Description: Step 88 Install the forward spring attach bracket
-manufacture quick removal nut plate for 3/8” tail gear front bolt-bend .032 aluminum plate to fit in radius of spring attach bracket-trial fit and trim to pick up 2 lower bracket holes and 3/8” bottom hole-bolt in place, open up 3/8” hole from bottom-remove bracket, deburr, clean, alodine and prime with zinc chromate-rivet MS 21047L6 anchor nut to aluminum angle with flush rivets-reinstall bracket and check anchor nut alignment-drill drain holes in bulkhead D on each side of bracket
