Brief Description: Electric elevator trim servo installation
-Steps 8, 9, 12, 13, 14-clearances to ribs inside servo cut-out measured-enlarged hole in top skin for servo (snug fit0 with rotary file-edges dressed with flat and round files-wiring notch position estimated and made on right side of cutout-servo checked for smooth installation in cutout -notch checked for clearance to wiring harness-servo pushrod bent in vice with plastic hammer as per manual template-hardware installed on pushrod-servo installed and connected to elevator trim tab
