- These fittings needed to be cut to size fit between the tabs and the cowls. - Sanded the fittings and the upper cowl to ensure proper bonding of the resin. Cleaned the area where bonding would take place.- Secured the fittings to the tabs on the tubes and cleaned the area where bonding would take place. - Saturated the fiber-glass cloth in resin and placed 4 layers on each fitting.
