Brief Description: EIS and Low Fuel warning light installation.
I decided to install a low fuel warning light for the header tank. That will give me about a 15 minute warning at cruise settings before fuel starvation. So I chose a location for the warning light at the top of the avionics stack. Also decided to install the EIS warning there too. Originally I planned to leave this out. Since the EFIS displays will handle the same warnings. But I will use it mainly for oil pressure warnings at startup when the EFIS displays won't be powered up till after engine start. Carefully drilled up the holes and deburred. Then installed the warning lights.
