My EFIS setup has the fuel flow option. So I found a suitable place to locate it in the center console. That should avoid any turbulent flow. Although I had to fabricate a mounting bracket for it. Piece of cake! Actually a couple pieces of aluminum riveted in place. And then I used some solder crimps to connect the wires to the EFIS, power, and ground.
