Scotts Kitfox Sport project
Date:  11-26-2008
Number of Hours:  9.30
Brief Description:  Final spraying of Aerothane.
Sanded cowl bonnet, trim tabs, and upper cowl with 400 grit sandpaper in preparation for Aerothane spraying. The cowl bonnet had already been sprayed in Aerothane. But I ended up with a couple of runs by the NACA air ducts. So I had to sand them out and repaint. I cleaned all parts with C-2210 solvent followed by a tack cloth. Then sprayed 3 cross coats of Aerothane.
