Cleaned parts with C-2210 solvent using the double wipe method. Followed by a tack cloth. Then sprayed three cross coats of white Aerothane. Allowing paint to tack up between coats. Then engine mount was a bit difficult to paint and I did get some runs trying to paint all those tubes. But those will be fine since it's under the cowl.
