Brief Description: Bonding foam blocks to wing struts.
Started by sanding down the Super Fill that I previously applied to the L/H wing strut. Then I rough fit some foam blocks to the ends of the PVC strut fairings. As well as an area on the R/H strut that I needed to replace. But the PVC strut material is no longer available. With the foam carved out to a rough shape, I bonded the foam blocks in place with Super Fill.
