Brief Description: Electric carb heat probe installation.
I removed the carb drip pans and installed a couple of electric carb heat probes in the carb bodies. Then reinstalled the drip pans. These electric carb heaters are originally designed for the HKS engine. But are adaptable to the Rotax 912 since they both use the same carb.
