Layed out locations for wing inspection holes on lower wing and glued plastic grommets to wing. Then I fabricated several doilies for the wing inspection holes. And applied a bed of Polybrush for the inspection hole fabric doilies. Then I fabricated some custom fabric gussets for the wing penetrations on the lower surface. And applied fabric reinforcements to the lower surface of the wing. Then I finished by applying the finishing tapes to the leading and trailing edges.
