Scotts Kitfox Sport project
Date:  8-23-2003
Number of Hours:  7.00
Brief Description:  L/H wing fabric covering.
Solvent cleaned wing structure in preparation for fabric covering. Then mixed up a batch of thinned Polybrush. Three parts Polybrush to one part reducer. And applied 2 coats to leading edge, trailing edge, all ribs, and top of fuel tank. Then I rolled out some fabric onto the lower surface of the wing. And rough trimmed to size. Next I positioned fabric and secured it to the trailing edge with clothespins. Then starting at rib #1, I began gluing it down to the ribs working my way out to the tip. Next I glued down the lower surface of the trailing edge. Then the forward edge. With the fabric bonded to the lower surface, I flipped the wing over and scalloped the fabric on the leading edge with the pinking shears. Then bonded it to the leading edge. And finished up by bonding the fabric to the top of the trailing edge.
