I fabricated a mounting plate to connect the autopilot pitch servo to the pitch pushrods. The plate is fabricated from 3/16" aluminum plate. I then reconnected the pushrods with some longer bolts for the servo connection plate. Then I cut a length of pushrod to connect the servo. And installed the rod ends and bolted to servo. Finished by verifying proper travel and clearance of all components.
