I started by installing the pitch trim torque tube to the elevator. Then I hooked up the push-pull cable and adjusted the fit of the rear push pull bracket. Once satisfied with the location, I drilled it up. Then deburred the holes. Applied some structural epoxy to the faying surface and riveted it in place. Connected all hardware and rigged.
