Adjusted the fit of the nose wheel pant. And drilled up the forward bolt holes. Then used a tap to make threads in the nose gear fork for the screws. Then layed out the hole locations for the halves to bolt together. Drilled up nutplates, countersunk, and riveted nutplates to fairing half. Bolted both halves together and applied some more filler to several bubbles found in the gelcoat.
