Applied 2 coats of UV smooth prime to the cowl bonnet and wing cuffs. Also had several pinholes show up on the lower engine cowl and main gear wheel pants after spraying epoxy primer. So I sanded those areas and applied 2 coats of UV smooth prime there as well.
