Prepared L/H wing for fabric covering by applying 2 coats of Polybrush to wing rib, leading, and trailing edges. After allowing Polybrush to cure, I rolled out some fabric onto the wing. And began bonding fabric starting at the pitot tube. And working my way out bonding to the ribs first. Then to the leading and trailing edges. Same process as done with the L/H wing.
