Installed gas spring studs in door frame and brackets. And torqued to 80 inch lbs. Then fit gas springs to studs. Adjusted door frame bracket to give best fit for doors. And marked location. Then drilled brackets up on door frames. Disassembled and deburred holes. Mixed up a batch of Hysol mixed with microballons. Applied to faying surface of brackets and installed with pull rivets.
