Fabricated two heater mount attachment angles. Located angles on heater core and drilled up holes. Deburred parts and riveted attach angles to the heater core. Then installed assembly in fuselage with adel clamps. Then temp installed firewall and marked hole locations for heater hose connection. Removed firewall and cutout holes in firewall. Deburred holes. Then reinstalled firewall to check fit.
