Had to disassemble both adjustable rudder pedal handles and trim the springs a little shorter. They would bottom out too early and not allow the handle to come out the detents. Reassembled both handles with detent brackets and check for function. Also put detent bracket in place for the flaps to check function. Then located and drilled up trim lever assembly on console. Temp fastened center console in place and checked operation of adjustable rudder pedal handles. All handles in console function properly.
