Scotts Kitfox Sport project
Date:  6-29-2003
Number of Hours:  1.40
Manual Reference:  14
Brief Description:  Horizontail stabilizer installation.
Reamed out 7 hole locations to .4375 dia. Pressed 7 bronze bearings into holes. Using loctite to secure them into place. Mounted the horizontal stabilizer into place on the fuselage at the aft pivot point. Had to do a lot of grinding on the outer surface of the bearing to get it to fit into the bronze bushing. Then installed stabilizer struts and adjusted there length.
